Steering pump noise
2002 HONDA ACCORD
150,000 MILES
GMAN1983
My steering pump makes a constant noise once it has warmed up and has taken a few turns. I changed the pump but it continues to make the noise. There is no bubbles or foam in the container so I don't think any air is leaking in. Not sure what else it could be???
Apr 28, 2013 at 10:05 AM
new or used pump????
if the pump pressure is good, the rack and pinion may have failed
Apr 28, 2013 at 10:08 AM
GMAN1983
it was a refurbished pump. How can you test the pressure?
Apr 28, 2013 at 10:12 AM
GMAN1983
I don't think it is the rack or pinion cause I don't have an issue with steering
Apr 28, 2013 at 10:20 AM
