Hard to steer at lower rpm's
2001 FORD F-250
205,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
FORDSUPERDUTY1
Steering seems to get hard to steer when I apply brakes to the vehicle like when I am backing into garage Less so when at higher rpm's. Have already replace power steering pump This does not have a Hydro boost system Has a lot of mechanics in town stumped. It is like it gets very hard to stee , no belt slipping etc.
Nov 3, 2016 at 7:26 AM
HMAC300
  • 48,601 POSTS
Ford says this is normal especially if you have bigger tires on truck. make sure you have grease-able ball joints on lower and if belt was replaced the tensioner should have been as well. recommended replacement for both is 60,000 miles.
Nov 3, 2016 at 9:38 AM
FORDSUPERDUTY1
it just started doing this all at once which lead everybody to think power steering pump. same size tires as recommended. No problems for 200,000 miles, until now.
Nov 3, 2016 at 10:17 AM
HMAC300
  • 48,601 POSTS
then the only thing I can recommend is to replace the hydro boost with a factory one as tips form other mechanics have done that but still have the same problem. make sure you can grease your front end as well as that seems to be one of the fixes.
Nov 3, 2016 at 11:58 AM
FORDSUPERDUTY1
will make sure it is greased. Unit is serviced every 3,000 miles since new. Does not have a Hydro boost on it just a regular master cylinder and vacuum for the brakes.
Nov 3, 2016 at 12:36 PM
HMAC300
  • 48,601 POSTS
sorry, I misread the hydro boost on this. the only other thing I can really think of is if the spring for the spool valve broke it will make the valve inside do screwy things or maybe due to age and mileage the balls may be hanging up either on return or on shaft itself. Maybe because of lower pressure, I cannot really think of anything else.
Nov 3, 2016 at 1:01 PM
Does the pump have wires going to it? If so then there are a few sensors it could be that controls the pump output pressure.
Please let us know
Best, Ken
Nov 3, 2016 at 1:56 PM
