Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
2500
Steering
Column
Replace/Remove
Steering column
1990 CHEVROLET 2500
283,000 MILES • 5.0L • V8 • 2WD • MANUAL
STEVE HENNI
MEMBER
FOLLOW
Will a automatic column work in manual floor mounted shift and will neutral safety switch engage once I remove the autos shift rod?
Jul 4, 2017 at 3:31 PM
CERTIFIED EXPERT
Yes the column with work in the truck, you will not need to worry about the neutral safety switch becasue it is mounted to the clutch pedal.
Jul 5, 2017 at 5:25 PM
STEVE HENNI
MEMBER
Thank you very much since they are so expensive this helps a lot
Jul 5, 2017 at 5:36 PM
CERTIFIED EXPERT
Good to hear, please use 2CarPros anytime we are here to help.
Jul 5, 2017 at 5:48 PM
