steering boot cover?
2010 DODGE CHALLENGER
178,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
LEMONCAR
  • 36 POSTS
in the first picture the steering boot isn't completely on the plastic. Is that a concern and can i zip tie or hose clamp it back?
Second picture can i apply some lube to those areas and which kind can i use? i have heavy duty wheel hub / axle grease (green stuff) i have a white silicone grease and silicone spray.
Sep 22, 2022 at 4:55 PM
I wouldn't be overly concerned with pic 1. If you want, you can use a zip tie to hold it in place. Just make sure not to crush the plastic component when you tighten it.
The items in pic 2 can be greased as well. I would use a general grease, the same as what is used on steering components. If you have wheel bearing grease, it can be used.
However, I don't know if you will successfully get the grease into the joint. These are usually sealed and not serviceable.
I hope this helps. Let me know if you have other questions.
Sep 22, 2022 at 9:35 PM
LEMONCAR
  • 36 POSTS
Okay, thank you for the reply. With how this car has been acting the last few weeks with all these problems one after another i am trying to stay ahead of anything this car is ready to throw at me, lol saying that I will post some pictures on my blend door question. i found one area soaked in oil where the higher sitting actuator is on the driver side.
Sep 23, 2022 at 1:05 AM
Oil-soaked actuator? That's an odd one. I would love to see that. I'm not sure where it would have come from in that location.
Take care.
Sep 23, 2022 at 7:51 PM
