Humming noise in steering
2006 CHEVROLET AVALANCHE
188,000 MILES • 5.3L • V8
ETC420
Humming noise when steering wheel turned to right.
Dec 1, 2018 at 6:54 PM
Can you tell approximately where the humming sound is coming from? For example, does it seem to come from inside the vehicle or under the hood.
Dec 1, 2018 at 9:36 PM
ETC420
From front passenger side wheel area. Thank you
Dec 3, 2018 at 6:00 PM
Okay, I should have seen that when I first replied. Sorry. Anyway, it could be the result of a brake issue or a wheel bearing. Does the sound change when you apply the brakes? What happens when you turn left? Also, does the humming change with vehicle speed?
Honestly, it sounds like a wheel bearing, but I will wait for your reply.
Dec 3, 2018 at 8:37 PM
ETC420
No change applying brakes or speeding up. Noise only turning right.
Dec 4, 2018 at 1:44 PM
Hi again:
Is there any way you could record the sound and upload it so I can hear it? If it makes a humming should when turning right, that leads me to believe there is a problem with the left front wheel bearing.
Dec 4, 2018 at 6:24 PM
