Loud tire noise rumbling sound in the front of vehicle and pulls to right even after being aligned?
2002 FORD EXPLORER SPORT TRAC
198,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEREMY BRONSON
I put a tie rod end on the driver side the thing that connects to it turned on me when I put the new one on and I can't remember if it turned also when I took the old one off. But I did turn it back when I put the new one on. Please help.
Aug 6, 2022 at 9:33 AM
Not always, but in most cases, a pull left, or right is a brake-related issue. The rumbling you hear could be an overheated brake rotor.
When you apply the brakes, does the pull change? Does the vibration change?
Here is what I suggest: Safely lift the front of the vehicle. Have a helper apply the brakes so you can't turn the wheels. Have the helper release the brakes and see if they both release.
Aug 6, 2022 at 9:25 PM
