Steering feels loose
1992 CHEVROLET 1500
241,621 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BIGBRIAN18
When I drive my truck it goes down the road smooth and straight but I noticed my steering wheel has play or feels lose or something I got to keep it study with both hands left or right. When it sits still and wheels are sitting still an straight it still has play.
Jul 9, 2018 at 7:15 PM
Play in the steering is usually caused by worn steering components such as inner or outer tie rods, excessive play in the steering gear or rack and pinion, or a worn universal joint in the steering column. Here is a link which describes how the system works and the components involved, including the steering gear and tie rods. Look through it first.
https://www.2carpros.com/articles/how-car-steering-works
What I suggest is to first safely lift one of the front wheels off the ground at a time. Place your hands at 3 and 9 o'clock and move the tire back and forth to see if there is movement. If you have a helper, have that person watch where the movement is coming from on the steering linkages under the vehicle. If you find it is a ball joint, here are general directions for replacement:
https://www.2carpros.com/articles/tie-rod-end-replacement
Do this first and let me know what you find. Please keep in mind, any of these components can fail. The result will be a loss of steering, so check them closely.
Jul 9, 2018 at 8:38 PM
