My steering is light when I start off
2001 PEUGEOT 206
140,000 MILES • 1.1L • 4 CYL • 2WD • MANUAL
JORDANC523
My steering is light when I start off but ten minutes into driving it becomes really heavy but is still possible to steer okay.
Thanks in advance.
Jordan
Apr 10, 2017 at 4:54 AM
This issue is most likely a power steering pump that is failing. When the fluid is thick the pump is able to build pressure however, as soon as it starts to get hot, the pump loses the ability to build pressure because the fluid is thinner.
Here is a guide that will help with this:
https://www.2carpros.com/articles/power-steering-problems
I would suggest replacing the pump and then retest the system. Here is a guide that will help with this.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Unfortunately, we don't have a manual that will give the specifics, but this guide should help enough to get the job done.
Please run through this and let us know what questions you have. Thanks
Oct 28, 2021 at 3:56 PM
