Steering shaking
2012 HONDA CRV
77,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
SHAMIMAHMED71
  • 4 POSTS
My car shakes steering when I go above 55 to 70 mph especially when accelerating. I did balance and alignment, change front shocks, all brake pads, rear discs. no problem solve. please help.
Jul 6, 2020 at 3:57 AM
Good morning,
Did you rotate the tires? You could balance the tires but if you have a shifted belt, it will do this.
https://www.2carpros.com/articles/how-car-tires-work
Also, did anyone check the axles? A worn CV joint will also cause this shaking.
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/replace-cv-axle
Jul 6, 2020 at 4:07 AM
SHAMIMAHMED71
  • 4 POSTS
Yes, my mechanic check axle and CV joints.
Jul 6, 2020 at 4:18 AM
Okay, what about the tires? A shifted belt would cause this and balancing will not fix that.
Jul 6, 2020 at 4:33 AM
SHAMIMAHMED71
  • 4 POSTS
All 4 tires are new.
Jul 6, 2020 at 4:41 AM
Okay, they missed something.
Did they actually feel the shaking? They need to go over the front end again. I still think the CV joints are the issue. The inners were very common for causing steering vibrations especially when accelerating.
Jul 6, 2020 at 4:46 AM
SHAMIMAHMED71
  • 4 POSTS
I will go to my mechanic to check again the inner CV joint and I will change it let see. thanks for your advice.
Jul 6, 2020 at 6:24 AM
You are welcome.
Always glad to help.
Jul 6, 2020 at 6:26 AM
