Hi my jeep only starts when the battery terminal disconnect and wait for one mint then reconnect then it starts . i found there is a code P0340. i changed the camshaft position sensor but same again i checked the wire connection from cam sensor to TCM its good. i found that in the not starting time when we crank there is no spark coming in the spark plug. what shall i do. should i change the TCM. ?
Sep 24, 2015 at 7:48 PM
