Will not stay running
1995 CHEVROLET S-10
200,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
TODD MOORE
Had issue where under load it would spit and sputter. Replaced fuel pump, fuel filter, rotor cap and button,and pressure regulator. After replacing all this it ran fine for 3 or 4 minutes then started down road it shut off. Now it starts idles rough for a few seconds then shuts off. The spider injector is fine was replaced last summer. No fuel leaks, plenty of fuel pressure and is getting to the cylinders. Anyone have another idea or similar issue that they fixed? Thank y'all in advanced.
May 31, 2021 at 11:45 AM
Sounds like you have a vacuum leak somewhere. I would suggest we start with checking for a leak with the guide below.
If everything with a vacuum leak checks out we may need to check for an internal vacuum issue by hooking up a gauge.
Below is a chart that helps determining possible issues.
Here is a guide that helps with this issue in more general terms:
https://www.2carpros.com/articles/stall-at-idle
Please run through this material and let us know what happens. Thanks
May 31, 2021 at 6:20 PM
TODD MOORE
All vacuum lines have been checked with pressure gauge and referred to manuel for readings all are normal.
Jun 1, 2021 at 9:10 AM
If there are no vacuum leaks then we need to confirm what the fuel pressure is. When you say it has plenty of pressure, do you know what this is?
Let us know what the PSI is and we can go from there. Thanks
Jun 2, 2021 at 6:47 PM
TODD MOORE
80 PSI.
Jun 4, 2021 at 4:50 AM
That is way too high and is most likely your issue. High fuel pressure will cause the engine to run poor or not even run.
Take a look at all the attachments below. This will help run through how to figure this out.
However, it is most likely an issue with the return line. Please take note of the last page where it says not to run the engine with more then 75 PSI or you will damage the regulator.
Please let us know what you find with this. Thanks
Jun 5, 2021 at 8:11 AM
