Starts great uphill?
2003 GMC SAFARI
180,000 MILES
SKY74
It starts instantly in the morning when cold but once it's been running it takes two, three five second cranks to start, even if I let it sit for a few hours. However, if I park it facing uphill it will start right up instantly.
Mar 23, 2023 at 9:08 PM
I have seen a weak fuel pump cause this issue, but to be sure let's do a fuel pressure test. here is a guide to help with the instruction for your car and how to replace the fuel pump in the images below:
Fuel System Pressure (w/fuel pump running) .................... 379 - 427 kPa (55 - 62 PSI)
Fuel System Pressure (after fuel pump shuts off) .................... 34 kPa (5 PSI)
Fuel System Pressure Drop (after 5 minutes) .................... 14 kPa (2 PSI)
You can rent a fuel pressure gauge for cheap at the local auto parts store. Check out the images (below). Please let us know what happens.
Mar 24, 2023 at 6:50 PM
