Starts but will not stay running?
1998 CHEVROLET ASTRO
200,000 MILES
STEPHEN KRIS JOSEY
Changed just about everything except the block, no codes, but the van will fire idle for a second and then shut off. Anyone got a clue? I've done all of it for, crank sensor, MAP sensor, all of it and still the same thing.
Aug 29, 2022 at 8:42 PM
It sounds like the exhaust system is clogged or the fuel pump is going out. When the engine stalls can you hear the fuel pump working in the fuel tank? If not, I would replace the fuel pump. If you can hear it, I would remove the exhaust from the catalytic converter.
Here is a guide to help you and I have included how to change the fuel pump out just in case you need it:
Here is how you can drain the tank:
https://youtu.be/Q5MH2gnyFH0
Aug 30, 2022 at 10:41 AM
