The car will crank and idle for a couple of seconds and the car will die unless you press the pedal to keep up the RPM. More info... With the RPM sitting at 3,000 RPMs the RPM will constantly cut out to about 2,000 RPMs and go back to 3,000. Took it to firestone and they replaced a bad crank shaft sensor. However, car still has the same issue and they don't have a clue what might be the cause.
Aug 27, 2021 at 3:51 PM
