This could be the result of a few different things. First, check to see if there are any engine vacuum leaks. Here is a link that shows how to check:
Next, the idle air control valve (IAC) is responsible for maintaining engine idle speed. It is located on the throttle body. I attached two pics below (pics 1 and 2) showing the location. The IAC allows a metered amount of air enter the engine when the throttle plate is closed. So, if it is not functioning or is clogged with carbon, it will cause a problem
Here is a link that explains how to service the IAC:
https://www.2carpros.com/articles/idle-air-control-valve-service
If you determine it is bad, here are the directions for replacement. The last section below will indicate the relearn process.
These directions also explain how to inspect it.
1996 Chevy Truck C 1500 Truck 2WD V8-5.7L VIN R
Idle Air Control (IAC) Valve Replacement
Vehicle Powertrain Management Fuel Delivery and Air Induction Idle Speed/Throttle Actuator - Electronic Service and Repair Procedures Idle Air Control (IAC) Valve Replacement
IDLE AIR CONTROL (IAC) VALVE REPLACEMENT
Throttle Position Sensor Electrical Connector
pic 3
pic 4
pic 5
pic 6
REMOVAL PROCEDURE
1. Remove the electrical connector from the Idle Air Control (IAC) valve
2. Remove the IAC valve attaching screws.
CAUTION: If the IAC valve has been in service: DO NOT push or pull on the IAC valve pintle. The force required to move the pintle may damage the threads on the worm drive. Also, DO NOT soak the IAC valve in any liquid cleaner or solvent, as damage may result.
3. Remove the IAC valve assembly.
4. Remove the O-ring.
CLEANING AND INSPECTION PROCEDURE
1. Clean the IAC valve O-ring sealing surface, pintle valve seat, and air passage.
Use the carburetor cleaner and a parts cleaning brush in order to remove carbon deposits. Follow instructions on the container.
Do not use a cleaner that contains methyl ethyl ketone, an extremely strong solvent and not necessary for this type of deposit.
Shiny spots on the pintle or seat are normal. They do not indicate misalignment or a bent pintle shaft.
If air passage has heavy deposits, remove the throttle body for complete cleaning.
2. Inspect the IAC valve O-ring for cuts, cracks, or distortion. Replace if damaged.
NOTE: If installing a new IAC valve, replace with an identical part. The IAC valve pintle shape and diameter are designed for the specific application.
3. Measure the distance A between tip of IAC valve pintle and mounting flange. If greater than 28 mm, use finger pressure in order to slowly retract the pintle. The force required to retract the pintle of a new valve will not cause damage to the valve.
MEASUREMENT PROCEDURE
NOTE: If installing a new IAC valve, replace with an identical part. The AC valve pintle shape and diameter are designed for the specific application.
INSTALLATION PROCEDURE
2. Lubricate the IAC valve O-ring with clean engine oil.
2. Install the IAC valve assembly.
3. Install the attaching screws.
Tighten
Tighten the IAC valve attaching screws to 3.0 Nm (26 lb. in.).
4. Install the electrical connector.
5. Reset the IAC valve pintle position.
5.1.Turn the ignition switch to the ON position for 5 seconds.
5.2.Turn the ignition switch to the OFF position for 10 seconds.
5.3.Start the engine.
5.4.Check for the proper idle operation.
Reset directions:
Idle Air Control (IAC) Reset Procedure
Vehicle Powertrain Management Fuel Delivery and Air Induction Idle Speed/Throttle Actuator - Electronic Service and Repair Procedures Idle Air Control (IAC) Reset Procedure
IDLE AIR CONTROL (IAC) RESET PROCEDURE
1. Turn the ignition switch to the ON position for 5 seconds.
2. Turn the ignition switch to the OFF position for 10 seconds.
3. Start the engine.
4. Check for the proper idle operation.
___________________________
Nov 6, 2020 at 7:51 PM
