Starts but idles
2002 NISSAN SENTRA
FIXMACAR
  • 13 POSTS
Hi, i have a 2002 nissan sentra 1.8 that starts but it idles, and when i accelerate it has no power, it'll sound fine for second then it'll idle again, i put it in drive and it will idle with no power...I replaced the EGR valve, air control valve, fuel regulator, and the crank shaft sensor..and it doesn't change a bit, it did once it turned on fine and it didn't idle but it turned off in about 40 minutes
May 18, 2013 at 10:25 PM
KHLOW2008
  • 41,814 POSTS
Start with a check for trouble codes and let us know if any found.
May 19, 2013 at 12:56 AM
FIXMACAR
  • 13 POSTS
My code scanner read...p0101, p0103, p033Do you think it could be the wiring or the harness
May 19, 2013 at 10:55 AM
KHLOW2008
  • 41,814 POSTS
P0101 and P0103 is a fault with the MAF or its circuit. It can be the MAF or its wiring that is faulty and you would need to perform tests to find out the actual cause.
P033 is incomplete, can you please reconfim?
May 20, 2013 at 9:45 AM
FIXMACAR
  • 13 POSTS
p0335
May 20, 2013 at 10:21 AM
KHLOW2008
  • 41,814 POSTS
P0335 is a fault detected within the crankshaft sensor.
Any of these codes are possibilities and what you should do now is to erase them and after going for a test drive, recheck the codes to reconfirm which ones comes up.
May 20, 2013 at 6:04 PM
FIXMACAR
  • 13 POSTS
I already erased the codes and started the car, because i cant test drive the car...The car will just start but it will idle with no power, if i accelerate its like Im not even accelerating
May 20, 2013 at 6:09 PM
KHLOW2008
  • 41,814 POSTS
Are the same 3 codes still present?
May 20, 2013 at 6:17 PM
FIXMACAR
  • 13 POSTS
Yea they all are there...did it a few times already, I erased them waited a few minutes started it left it running and scanned it again and they all came back
May 20, 2013 at 7:17 PM
KHLOW2008
  • 41,814 POSTS
Yuo would have to start diagnosing the cause. Check the wire harness of the MAF for contamination, looseness etc. Check cranksensor wireing as well.
If they all look good, you would need to check for continuity between sensor and ECU.
May 21, 2013 at 6:54 AM
