I bought this vehicle with a supposed bad fuel pump. I have found my problem is not fuel system related. New fuel pump , filter and regulator. Still same issue. The battery was new but totally dead when I bought the car. After charging battery, I found that when you turn the key on, the fuel pump stages as it should and the only instrument light that comes on is the check engine light. Fuel gauge works but no idiot lights. When you turn the switch to start, the engine fires, stumbles for just a second, then dies, the check engine light goes out and the engine will not fire at all until the key is turned off and then back on to stage the fuel pump again. I think someone had been investigating before because of evidence I have found with dash screws out and/or loose etc. Do you have any idea of where/ what to look for etc? Im stumped right now. Oh, all the exterior lights come on with the key, not just the daytime running lights. Thanks. Please help.
Oct 11, 2019 at 8:16 AM
