starts and shuts off, but if i hold the gas pedal down it stays running as soon as i let it go it shuts off. I have check the low fuel pressure the one that come from the tank 55 - 60 PSI. One time i had it running for two seconds with fuel pressure gauge on it but the gauge needle did not stay stable flickering around. This happened after they replaced all three catalytic converters with aftermarket parts and camshaft sensor bank 1 sensor B . The codes come up on EOBD p0017, p0420, p0430. It said no code found on DTC and every time cleared the code they never went away. Also, I cleaned MAF and throttle body still the same.
Mar 15, 2023 at 10:43 AM
