Okay, controller? Do you mean the relay? The ECM is what controls the fuel pump relay based on the input from the ignition system.
I attached the wiring diagram for you as well as the location of the fuel pump relay.
FUEL PUMP MODULE REMOVAL:
WARNING: The fuel system is under constant pressure, even when the engine is OFF. Always release fuel pressure before servicing any fuel system component.
Fuel Hose Fitting On Fuel Pump Module
1. Release fuel pressure.
2. Drain fuel tank.
3. Remove fuel tank.
4. While holding the fuel pump module down, remove the locknut, (locknut is threaded onto tank). Use a brass drift to loosen the fuel pump locknut. After the locknut has been removed release the fuel pump module and it will spring up from the fuel tank.
5. Remove the fuel pump module from the fuel tank.
DISASSEMBLY
Fuel Gauge Sending Unit And In-Tank Filter
FUEL GAUGE SENDING UNIT REMOVAL
1. Remove sending unit attaching screws from mounting bracket located on the side of the fuel pump reservoir.
2. Disconnect electrical connections from sending unit, and remove sending unit.
IN-TANK FUEL FILTER REMOVAL
1. Pry back the fuel filter mounting tabs and pull the fuel filter off of the fuel pump module.
NOTE: The fuel pump is not serviceable, if the pump is defective replace the whole fuel pump module.
ASSEMBLY
FUEL GAUGE SENDING UNIT INSTALLATION
1. Connect the electrical connections to the sending unit.
2. Install sending unit onto the fuel reservoir, and tighten the mounting screws.
IN-TANK FUEL FILTER INSTALLATION
1. Snap the fuel filter onto the mounting tabs of the fuel reservoir.
FUEL PUMP MODULE INSTALLATION
NOTE: Locknut and gasket must be replaced whenever the fuel pump module is serviced.
1. Wipe seal area of tank clean, and install a new seal on pump.
2. Install locknut over top of fuel pump module.
3. Push fuel pump module into the tank and hold with one hand while tightening the locknut with the other hand.
4. Install fuel tank assembly.
NOTE: ASD and fuel pump relays remain energized for 7 minutes during the following test, unless the test is stopped or the ignition switch is turned to the OFF position.
5. Using scan tool, place ignition switch in "RUN" position and use Actuate Output Test Auto Shutdown (ASD) Relay", to activate fuel pump and pressurize system.
6. Check for leaks.
Nov 13, 2020 at 4:35 AM
