Starts then shuts off
2013 DODGE DART
100,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SPIKETORRES
  • 23 POSTS
I had problems with my car turning off while driving about a year ago, but then last week it died on me. got my battery and alternator checked. Turned out my alternator was bad. My dad installed the new one and according to him he thinks the wire that goes from the alternator to the battery is bad, so he peeled the wires I guess to bypass the sensor, if it has one, and hooked it up directly to the battery. Then he tells me it's the battery. I got a new one and all the car does is start up immediately shuts off. What could be causing this.
Nov 8, 2019 at 3:37 PM
Good evening,
Can you post some pictures of the wire you are talking about for me to see?
Do you have a voltmeter to do some testing?
Nov 8, 2019 at 4:04 PM
SPIKETORRES
  • 23 POSTS
Yes, here are the pictures. I didn't know I would get a response this fast. I don't have a voltmeter though.
Nov 8, 2019 at 4:13 PM
Wow.
Okay, you will need to get a voltmeter to do some testing. We need to see if the alternator is working.
Is the check engine light on?
Nov 8, 2019 at 4:15 PM
SPIKETORRES
  • 23 POSTS
It does not come on.
Nov 8, 2019 at 4:23 PM
Okay, you need to either buy a voltmeter or borrow one from someone so we can do some checks and see what is going on.
Nov 8, 2019 at 4:28 PM
SPIKETORRES
  • 23 POSTS
I'll have to go get a voltmeter to test it. I didn't expect to get an answer this quick so I didn't prepare.
Nov 8, 2019 at 4:29 PM
It is okay.
Let me know when you are ready to do some testing.
Nov 8, 2019 at 4:31 PM
SPIKETORRES
  • 23 POSTS
Okay and thank you. I'll try to get one right now.
You are welcome.
Nov 8, 2019 at 4:41 PM
SPIKETORRES
  • 23 POSTS
So I can't get access to a voltmeter yet, maybe until tomorrow morning. I do however have this video of what the car does when I try to turn it on. I don't know if this helps at all.
Nov 8, 2019 at 4:57 PM
SPIKETORRES
  • 23 POSTS
After I turn everything completely off, I hear this kind of clicking noises coming from what seems to be on the relay box behind the battery also followed by one that seems to be coming from under or at least close to the engine.
Nov 8, 2019 at 5:03 PM
This sounds like an ignition switch. It starts in the start position and shuts off in the run position.
REMOVAL
1. Disconnect the and isolate the negative battery cable.
2. Remove the dash end cap See: Dashboard / Instrument Panel > Removal and Replacement > Instrument Panel End Cap - Removal.
3. Remove the steering column opening cover.
4. Remove the HVAC control head See: Control Assembly, HVAC > Removal and Replacement > A/C And Heater Control - Removal.
5. Remove the instrument cluster bezel See: Dashboard / Instrument Panel > Removal and Replacement > Instrument Cluster Bezel - Removal.
6. Disconnect the wire harness connector from the Ignition Node Module.
7. Remove 4 screws from the I/P holding the Ignition Node Module in place.
8. Remove the Ignition Node Module from the backside of the I/P.
Nov 8, 2019 at 5:04 PM
This could still be related to the ignition switch.
Nov 8, 2019 at 5:09 PM
SPIKETORRES
  • 23 POSTS
Is there a way to check to see if it is the ignition switch before I get the part?
Nov 8, 2019 at 6:01 PM
That will be done with the voltage checks we will do.
Nov 8, 2019 at 6:07 PM
SPIKETORRES
  • 23 POSTS
Okay, I have a voltmeter. Also I disconnected that wire I showed you on the first picture I sent you. And connected the original and I managed to turn the car on, but after a while it shut off. I recharged the battery and it turned on again and then shut off again.
Nov 9, 2019 at 12:36 PM
Okay, check the voltage at the battery with the engine running. Tell me what you find.
Nov 9, 2019 at 12:48 PM
SPIKETORRES
  • 23 POSTS
Now I can't get it to come on. I have a small 6 amp battery charger hooked up to the battery and every time I turn the ignition the voltage on the battery drops to around 11.7.
Nov 9, 2019 at 12:57 PM
SPIKETORRES
  • 23 POSTS
Okay, the voltage is 10.5 and keeps going down when it is on.
Nov 9, 2019 at 1:00 PM
SPIKETORRES
  • 23 POSTS
It went down to 8 and shut off.
Nov 9, 2019 at 1:01 PM
Battery is dead. You need to charge it up until the reading is 12.6 volts. That is a full charge.
Nov 9, 2019 at 1:04 PM
SPIKETORRES
  • 23 POSTS
I charged it to 12.5 then turned it on and immediately started dropping down and shut off.
Nov 9, 2019 at 1:15 PM
What was the voltage again when it started?
Nov 9, 2019 at 2:08 PM
SPIKETORRES
  • 23 POSTS
When it was off it was 12.5 but as soon as it turns on it drops to around 10.5 and just keeps going down.
Nov 9, 2019 at 2:21 PM
You have a bad battery.
Nov 9, 2019 at 2:22 PM
SPIKETORRES
  • 23 POSTS
It's a brand new battery. You think it's bad already? It's not even 3 days old.
Nov 9, 2019 at 2:25 PM
SPIKETORRES
  • 23 POSTS
Once I turn it off the car, the battery stays at around goes up to about 11.8 and stays there.
Nov 9, 2019 at 2:31 PM
If it dropped to 10.5, it is bad.
Where did the 11 come from?
Nov 10, 2019 at 4:47 AM
SPIKETORRES
  • 23 POSTS
Sorry, I have been busy so I hadn't had time to work on the car. Okay, earlier this week I looked at it more closely. My dad unplugged the alternator wire from the alternator but left it connected to the battery on a 200amp fuse which has two terminals. I then unplugged it from the battery so that was eliminated completely. I then hooked up another wire from the alternator to the battery at the opposite terminal at the 200 amp fuse connection and it seemed to be working for about 2 days, the only thing is it wouldn't start up in the morning until about the 3rd push of the ignition button. So we got a new fuse to replace the old one and hooked everything back up like normal and it went back to the starting up and immediately stalled.
Nov 15, 2019 at 3:57 PM
When you turn on the key, does the theft or security light go out after 10 seconds?
Nov 15, 2019 at 4:01 PM
SPIKETORRES
  • 23 POSTS
It turns off within about 2-3 seconds.
Nov 15, 2019 at 4:38 PM
Again, the lights? Please tell me about the lights?
Nov 15, 2019 at 5:04 PM
SPIKETORRES
  • 23 POSTS
Everything comes on on the dash like normally. no check engine light or anything just the battery light stays on again. but I've been checking it and it stays at around 12.6v.
Nov 15, 2019 at 5:21 PM
Okay, let me be more specific.
I am asking you if the theft light or security light comes on and goes off. If it stays on, it is a security issue for the engine cutting off.
If it is not then we need to look somewhere else like the ignition switch.
Nov 15, 2019 at 5:27 PM
SPIKETORRES
  • 23 POSTS
Yes, the red security light comes on and then goes away when the engine shuts off.
Nov 15, 2019 at 5:44 PM
Okay, when you turn the key to on, not running, does the light stay on or does it go off after 10 seconds?
Nov 15, 2019 at 5:52 PM
SPIKETORRES
  • 23 POSTS
Okay. The security light comes on and goes away within 2-3 seconds.
Also when I do that without turning on the car, it gives me a message on the radio screen to enter anti theft code, but only when I push the "start" button on the car without starting the engine.
Nov 16, 2019 at 8:54 AM
The radio code has nothing to do with starting the car.
Does it start right back up after it stalls?
https://www.2carpros.com/articles/stall-at-idle
Nov 16, 2019 at 9:03 AM
SPIKETORRES
  • 23 POSTS
I can keep starting it up and it keeps stalling.
Nov 16, 2019 at 9:17 AM
I think at this point you are going to need some help from someone familiar with this system to help.
They will need a scan tool to look at live data to see what is causing the engine to shut off.
Nov 17, 2019 at 8:13 AM
