STARTING PROBLEMS
1987 MAZDA B2200
150,000 MILES • 4 CYL • 2WD
SXAPS
  • 6 POSTS
My truck cranks but does not start, it sounds like the starter slips? What do you the problem is?
Apr 14, 2016 at 8:11 AM
HMAC300
  • 48,601 POSTS
it may be the starter drive is shot, when this happens vehicle will just start to fire and starter whines instead of continuing to turn it over. replacement of starter is cure
Apr 14, 2016 at 9:34 AM
SXAPS
  • 6 POSTS
Thank you..and one moreHOW DO I SET IDLEING ROAD RIGHT
Apr 14, 2016 at 4:38 PM
HMAC300
  • 48,601 POSTS
if it's a carb it probably needs a carb overhaul due to alcohol in fuel. you can try to adjust the idle speed and check for vacuum leaks.
Apr 15, 2016 at 6:35 AM
SXAPS
  • 6 POSTS
IS THERE A SPECIAL WAY TO CHECK FOR VACUME LEAKS..ANS HOW WOULD I KNOW IF ITS A CARB
Apr 15, 2016 at 11:50 AM
HMAC300
  • 48,601 POSTS
scan for codes first if you can see pic 1 for carb adjustment remove screw 25 and shoot choke cleaner in hole then blow out with air. lightly seat screw and go out 1 and half turns. this is not a good pic of this carb so I thinkit's double arrow screw for idle. carb should still be overhauled. also this is a mikuni carb so may not be right as there are two different ones.
Apr 15, 2016 at 1:23 PM
HMAC300
  • 48,601 POSTS
our system is so good I can't send pics on reply
Apr 15, 2016 at 1:24 PM
