Since there is no black smoke and you see no leaks, I suspect it is the pump. Here are the directions for replacement. The first part is tank removal. The second explains how to remove the sender / pump. All pics correlate with the directions.
__________________________
2003 Chevy Truck K 1500 Truck 4WD V8-6.0L VIN U
Fuel Tank Replacement (Pickup)
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Service and Repair Removal and Replacement Fuel Tank Replacement Fuel Tank Replacement (Pickup)
FUEL TANK REPLACEMENT (PICKUP)
Fuel Tank Replacement (Pick-Up)
pic 1
REMOVAL PROCEDURE
1. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure.
2. Drain the fuel tank. Refer to Fuel Tank Draining Procedure.
See: Fuel Tank > Procedures > Fuel Tank Draining
3. Remove the fuel tank fill pipe.
4. Remove the evaporative emission (EVAP) canister.
5. If equipped, remove the fuel tank shield bolts.
6. Remove the fuel tank shield.
pic 2
7. Disconnect the fuel feed/return pipes from the fuel tank pipes.
8. Cap the fuel and EVAP pipes in order to prevent possible fuel/EVAP system contamination.
9. Place a suitable adjustable jack under the fuel tank.
pic 3
10. Remove the fuel tank strap bolts.
NOTE: Refer to Damage to Fuel Tank Straps Notice in Service Precautions See: Fuel Tank > Vehicle Damage Warnings > Damage to Fuel Tank Straps Notice.
11. Remove the fuel tank straps.
12. Lower the fuel tank until the electrical connections are accessible.
pic 4
13. Remove the fuel sending unit connector position assurance (CPA) connector.
14. Disconnect the fuel sending unit and pressure sensor electrical connectors (1).
15. Completely lower the fuel tank.
16. With the aid of an assistant, place the fuel tank in a suitable work area.
pic 5
17. Disconnect and remove the fuel feed (3) and return (2) pipes from the sending unit and retaining clips.
18. Disconnect and remove the EVAP pipe (1) from the sending unit, roll over valve (3), and retaining clip.
19. If replacing the fuel tank, remove the sending unit.
pic 6
INSTALLATION PROCEDURE
1. If the fuel tank was replaced, install the sending unit.
2. Install and connect the EVAP pipe (1) to the sending unit, roll over valve (3), and retaining clip.
3. Install and connect the fuel feed (3) and return (2) pipes to the sending unit and retaining clips.
pic 7
4. With the aid of an assistant, place the fuel tank on the jack.
5. Raise the fuel tank until the electrical connections can be made.
6. Connect the fuel sending unit and pressure sensor electrical connectors (1).
7. Install the fuel sending unit CPA connector.
pic 8
8. Install the fuel tank straps.
NOTE: Refer to Fastener Notice in Service Precautions See: Powertrain Management > Vehicle Damage Warnings > Fastener Notice.
9. Install the fuel tank straps bolts.
Tighten
Tighten the bolts to .....................................40 N.m (30 lb ft).
10. Remove the adjustable jack from under the fuel tank.
pic 9
11. Remove the caps from the fuel and EVAP pipes.
12. Connect the fuel feed/return pipes to the fuel tank pipes.
13. Install the fuel feed/return pipes to the clip on the fuel tank.
pic 10
14. If equipped, install the fuel tank shield.
15. Install the fuel tank shield bolts.
Tighten
Tighten the bolts to .....................................18 N.m (13 lb ft).
16. Install the EVAP canister.
17. Install the fuel tank fill pipe.
19. Install the fuel fill cap.
20. Connect the negative battery cable.
21. Use the following procedure in order to inspect for leaks:
21.1.Turn the ignition ON, with the engine OFF, for 2 seconds.
21.2.Turn the ignition OFF for 10 seconds.
21.3.Turn the ignition ON, with the engine OFF.
21.4.Inspect for fuel leaks.
________________________________________
Fuel Sender Assembly Replacement
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Unit Service and Repair Procedures Fuel Sender Assembly Replacement
FUEL SENDER ASSEMBLY REPLACEMENT
TOOLS REQUIRED
J 44402 Fuel Tank Sending Unit Wrench
pic 12
REMOVAL PROCEDURE
1. Remove the fuel tank.
2. Disconnect fuel lines from the sending unit, if required.
3. Using J 44402 , remove the sending unit lock ring.
pic 13
4. Remove the sending unit and seal. Discard the seal.
CAUTION: Drain the fuel from the fuel sender assembly into an approved container in order to reduce the risk of fire and personal injury. Never store the fuel in an open container.
5. Clean the sending unit sealing surfaces.
CAUTION: In order to reduce the risk of fire and personal injury that may result from a fuel leak, always replace the fuel sender gasket when reinstalling the fuel sender assembly.
IMPORTANT: The fuel strainer must be in a horizontal position when the sending unit is installed in the tank. When installing the sending unit, assure that the fuel strainer does not block full travel of the float arm.
pic 14
1. Install a NEW sending unit seal.
2. Align the tab, and install the sending unit.
pic 15
3. Using J 44402 , install the sending unit lock ring.
4. Connect fuel lines to the sending unit, if required.
5. Install the fuel tank.
Let me know if this helps.
Jan 25, 2021 at 11:47 AM
(Merged)
