Hello, I put key in the ignition switch and turn all the way to the other end to start. The engine does not start, it sounds like its trying and the ignition switch seems to hang in the position that is all the way to the end. I have to manually pull it back and it stops trying to start. It takes a few times but it started the other day. This started happening the other day, it seemed to delay on the start up like it was hanging in the start up position and now i have to try to start it multiple times. Do you think it might be the starter or the key ignition switch?
Jul 4, 2017 at 9:43 AM
