try to restart it it wont crank.
2000 HONDA CRV
150,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DONNIE HERRON
When the engine is warm and I turn it off and try to restart it it wont crank. Wait five to ten minutes and it will start. What could be the problem causing it not to start?
Oct 12, 2016 at 11:57 AM
RENEE L
  • 1,260 POSTS
Hi DONNIE,
Here is a link to an informative article from this site with step by step instructions and photographs on what to check for when your vehicle will not crank over.This sounds like the starter is having problems or the battery needs to be load tested these guides can help us fix it.
https://www.2carpros.com/articles/starter-not-working-repair
and
Please run down these guides and report back. I hope this helps you. Thank you for visiting 2CarPros.com.
Regards,
Renee
Admin
Jun 25, 2020 at 12:12 PM
