Starting issues
2005 HONDA ELEMENT
206,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
FMARSH2005EL
  • 12 POSTS
Would not crank. replaced battery, heard buzzing, replaced starter relay, buzzing stopped, but it would not start. I was advised to consider a new starter, bought a new starter tried to replace using Youtube. got it started and asked a mechanic friend for help he replaced starter, cranked right up shut off and would not start again.
Dec 21, 2016 at 6:23 PM
HMAC300
  • 48,601 POSTS
try resetting security system, see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 22, 2016 at 5:59 AM
FMARSH2005EL
  • 12 POSTS
Tried the steps and no change. Is the key fob necessary? Ours pooped out and we just use the key. Thanks!
Dec 22, 2016 at 6:00 PM
HMAC300
  • 48,601 POSTS
yes, because the key has a transponder in it to complete the circuit If it is not new. if it is a new key it has to be programmed by a mechanic so your car will start.
Dec 23, 2016 at 6:39 AM
