starts briefly after much cranking then shuts off suddenly, will not rev past 2,000 RPMs?
2007 SUZUKI SWIFT
107,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
IZAK1312
Hi there,
Also, when turning on the ignition there seems to be a lot of click in the engine coming from the starter relay, I've had a diagnostic reader pugged onto it and no faults come up.
Mar 29, 2023 at 10:20 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. Also, I would do a fuel pressure test because it sounds like the fuel pump is weak. You can rent a gauge set at the local auto parts store for cheap or free, please follow this guide to do the test:
Fuel Pressure .................... 379-393 kPa (55-57 psi)
This guide may help as well:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Please go over these guides and report back.
Mar 30, 2023 at 12:17 PM
