Will not start and random errors
2012 BUICK VERANO
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
KHSATER
I'm trying to determine why my vehicle won't start. The battery is brand new and I tried jumping anyway, so that seems to be ruled out. When I try to start, I get a single click and nothing else. After a few seconds (auto ignition times out) I get three error messages: driver side window needs to be reset, stabilitrack needs maintenance, and power steering needs service. I tried a hard reset by removing a battery terminal connection as well. I checked many of the fuses including every one that seemed to be ignition related. I did notice that the relay for EGR/Coolant Pump/AIR Solenoid Valve was inserted crooked and the pins were bent. I straightened them and tried starting with and without the relay installed. Nothing changed with either scenario.
Recently, the timing chain and a gear were replaced, so it seems possible that something was messed up then. Can you please advise me of any troubleshooting steps I might attempt?
Jan 4, 2020 at 4:05 PM
If you get one click and nothing more, the first things I would suggest is inspecting the battery terminals to make sure they are clean and tight as well as the main ground to the engine block. Additionally, check to make sure the terminals on the starter are tight.
Here is a link that you may find of interest:
Next, the starter itself may be bad. Here is a link that explains how to test a starter:
https://www.2carpros.com/articles/starter-not-working-repair
Now, I have to ask. Has the engine run since the timing chain was replaced?
Jan 4, 2020 at 8:10 PM
