The gas gauge stopped working. So I decided to replace the sending unit in the tank and also replace the fuel pump because It is all one piece. Which I did and also replaced the in line fuel filter no problems. I went to start car it starts but only runs for maybe sixty seconds. now keep in mind this car ran perfectly before these repairs. I checked all the fuses and relays all good. Removed return line to fuel pressure regulator and found fuel pumping straight Through. If that is the return line why should that much fuel be returning to the tank? Is that normal? Otherwise I am stuck on this one. Need Help.
Jul 4, 2016 at 12:53 PM
