The codes: P1298 and P1071.
Alternator, starter, and battery tested good.
Keep having to jump start (or pop the clutch start sometimes). The last few times I was able to get it started without either of those. It just sounded tired, sluggish (sort of like flooded, but not, with clicking in the dash) but it finally started.
I replaced the sub ground cable in front and the negative battery cable/ground wire. This did not stop issue. I have been leaving it idling after a short trip (twenty minutes like one would if recharging battery after a jump start) and that seems to help it start up again the next day.
I was thinking of troubleshooting the main relay next, but I am not sure. I heard clicking in the dashboard when starting it while it was having trouble.
The only thing I can think that was out of the ordinary recently was that I used one 3 oz treatment in late January of Lucas The Complete Fuel Treatment with Injector Cleaner and fuel conditioners in the clear bottle with white label. The starting problems did not start until early March, though.
Apr 2, 2018 at 11:45 AM
