Hard time starting, oil in the radiator
1998 CHEVROLET SUBURBAN
170,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
COOLDOGG
  • 16 POSTS
It has a hard time starting once it has been running it runs good starts just fine. Fuel pump is good replaced it 200 miles ago.It is having issues with oil in the radiator that is when this started. It never gets hot it runs good, just does not want to start. It used to start right up moved from Wyoming to Florida and started to have this problem. It is my only vehicle and I have five kids. I have to get to the bottom of it soon so I can get it fixed. Please help me. Thank you for any ideas or if someone has had this issue before.
Oct 22, 2018 at 3:31 PM
Hi and thanks for using 2carpros.com
If you are getting engine oil into the cooling system, chances are you have either a bad head gasket or intake gasket. Either one could allow oil to contaminate the coolant. Confirm that there is no coolant mixing with the engine oil. If it is, you will see a thick creamy tan colored substance.
Lets start with a quick check of the head gasket. Take a look through this link. Follow the steps provided. Also, you will see what engine oil looks like if contaminated with coolant.
If that checks good, next we need to determine if the intake is leaking. Here is a link that shows how to check for engine vacuum leaks.
Let me know what you find.
Oct 22, 2018 at 6:58 PM
COOLDOGG
  • 16 POSTS
So the suburban once started runs good no issues no rough running no rough I deli ng the main problem I a having right now is it doesn't want to start new fuel pump I'm pretty sure its getting gas to it if you pump it more then 2 times its flooded I have been trying to figure it out my wife went to start it yesterday and it won't start i will fix the oil issue after I figure this out joe do you have a idea on what to do next on starting problem it has the Chevrolet 350 votec spider fuel injection motor
Oct 23, 2018 at 7:22 AM
COOLDOGG
  • 16 POSTS
Because its not what i asked the engine runs and the idle is fine there's no coolant in the oil this has nothing to do with what I need at the moment
Oct 23, 2018 at 6:01 PM
