Turn the key and it whines
1985 FORD BRONCO
98,000 MILES • 2.8L • 6 CYL • 4WD • MANUAL
GHOST640409
Okay, turn the key and it whines Ike it's running free. gets fuel. brand new relay bought today. New ICM, new ignition coil. looking at starter something is not right. missing wire? I see only one.
Jan 16, 2019 at 1:47 PM
Good evening,
Does the starter turn when you turn it to start? It was unclear in your post.
Jan 16, 2019 at 3:58 PM
GHOST640409
Yes, but it's like a whine.
Jan 16, 2019 at 10:14 PM
It sounds like the starter Bendix drive may have failed. It is what engages the flywheel to make the engine turn.
Procedure
EXC. DIESEL ENGINES
1. Disconnect battery ground cable.
2. Raise and support vehicle.
3. Disconnect starter cable from starter.
4. Remove starter motor attaching bolts, then disconnect ground cable and lower starter from vehicle.
5. Reverse procedure to install..
Jan 17, 2019 at 2:56 AM
