After replacing battery there is no power going to starter from switch
1999 CADILLAC ELDORADO
150,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
MYCUNNINGHAM
  • 5 POSTS
I replaced battery and it sparked. but now no power going to starter from switch. The warning screen is black and the A/C heater lights don't come on.
Oct 21, 2019 at 6:27 PM
Good evening,
Did you install the cables correctly? The red cable goes to the positive side and the black goes to the negative side.
If you installed it backward, you could have damaged many modules from the voltage surge.
There is a main fuse in the fuse block which may have failed. Hopefully, it is the only damage.
Oct 21, 2019 at 6:56 PM
MYCUNNINGHAM
  • 5 POSTS
Yes they are correct to my knowledge. I have tested all fuses in both fuse boxes.What main fuse are you talking about?
Oct 21, 2019 at 7:33 PM
You have 4 fuse blocks in the car. You have the underhood, left half, right half and rear fuse blocks.
When you tested the fuses, did you verify voltage at the fuses? A visual is not a good test. You must test for power at the fuses.
https://www.2carpros.com/articles/how-a-car-fuse-works
Oct 21, 2019 at 7:40 PM
MYCUNNINGHAM
  • 5 POSTS
Yes, tested them with a test light and with key on. You said 4 fuse blocks and only mentioned 3 which I have checked those you mentioned. Because I only found one in trunk.
Oct 21, 2019 at 7:45 PM
Under the hood, there are relay boxes that have a couple of fuses as well.
Does anything have power in the car? Do any lights come on at the dash?
Oct 21, 2019 at 7:48 PM
MYCUNNINGHAM
  • 5 POSTS
the check engine light comes on and that is it. Also the trunk and fuel door buttons in center don't work. Funny which doesn't help but radio does works.
Oct 21, 2019 at 7:54 PM
MYCUNNINGHAM
  • 5 POSTS
Anymore clues for me?
Oct 22, 2019 at 6:16 PM
Okay,
I attached a power distribution diagram. I highlighted a 50 amp fuse. Can you verify power on both sides for me?
Oct 23, 2019 at 4:18 AM
