Starting
1993 CHRYSLER LE BARON
96,800 MILES • 4 CYL • 2WD • AUTOMATIC
DAVEY BARCLAY
Turn over the key and it starts to turn over then quits and the “brake” light comes on on the instrument panel.
Nov 1, 2017 at 1:32 PM
CARADIODOC
  • 34,306 POSTS
Will the engine eventually crank and start if you cycle the ignition switch enough times? When it does not crank, do you hear a single rather loud clunk from under the hood each time you turn the ignition switch to "crank"?
Nov 1, 2017 at 5:11 PM
