When attempting to start the car does not recognize the key fob?
2016 HYUNDAI GENESIS
101,996 MILES • 3.8L • 6 CYL • 4WD • AUTOMATIC
i bought the car wrecked. no damage except right front wheel assembly Engine will not start the car doesn't seem to recognize the key fob when it comes time to start.
it that the BCM or some other component?
Apr 17, 2024 at 9:09 AM
It could be a few things. For example, the key itself, the receiver, or the ignition switch itself. What you need to do is scan the can-bus to determine if codes are stored by any of the modules on the vehicle.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if that is something you can do or have done.
Apr 24, 2024 at 6:37 PM
