Starter won't catch flywheel
2000 HYUNDAI SONATA
200,000 MILES • 2.5L • V6 • FWD • MANUAL
SYLVESTER J JONES
Have a new battery and new starter installed. The starter is spinning but not catching the flywheel it is actually grazing it. What is the issue an how can I fix it?
Mar 29, 2017 at 10:08 AM
STEVE W.
  • 15,113 POSTS
Either you have the wrong starter motor or the flywheel is damaged. Remove the starter and look at the flywheel teeth. If they are damaged you will probably need to replace the flywheel.
Mar 29, 2017 at 10:45 AM
