Starter solenoid
1996 JEEP GRAND CHEROKEE
250,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JIM HAMILTON2
  • 7 POSTS
As soon as I hook up my battery she tries to engage.
Jan 15, 2019 at 4:02 PM
Good evening,
The first thing I would do is remove the relay and see if it still cranks. If it does, it sounds like the starter. If it does not, then we need to do some voltage checks.
You will need a test light or voltmeter.
Jan 15, 2019 at 4:32 PM
JIM HAMILTON2
  • 7 POSTS
starter check out good, pulled the relay still tries to engage. was having some issuse's with the starter cable, got another one from the junk yard, had Jeep running before I changed the cable.
Jan 15, 2019 at 5:09 PM
Ok, what was the failure?
Jan 15, 2019 at 5:11 PM
JIM HAMILTON2
  • 7 POSTS
connecter clamp to the battery need to be sodered no room for that so I replaced the cable, this problem since
Jan 15, 2019 at 5:20 PM
I thought you just said it was fixed?
Jan 15, 2019 at 5:22 PM
JIM HAMILTON2
  • 7 POSTS
no not fixed, was giving a little history.
Jan 15, 2019 at 5:28 PM
You need to be more clear with that. It was confusing me with conflicting statements.
Anyway, remove the little wire on the starter solenoid and see if it still tries to start
Jan 15, 2019 at 5:31 PM
JIM HAMILTON2
  • 7 POSTS
Did that earlier. no it wouldn't start.
Jan 15, 2019 at 5:44 PM
If you removed the wire and it did not start and you pulled the relay and it started, then you have a short to power on that small wire to the solenoid.
Jan 15, 2019 at 6:03 PM
JIM HAMILTON2
  • 7 POSTS
so I should replace the solenoid wire?
Jan 15, 2019 at 6:14 PM
I would try to find the short in the harness. If you do not find it there may be future issues with other systems.
Jan 15, 2019 at 6:22 PM
JIM HAMILTON2
  • 7 POSTS
Okay, thanks. I'll try that in a few days.
Jan 15, 2019 at 6:31 PM
Sounds like a plan.
Jan 15, 2019 at 6:55 PM
