I am replacing the starter on my wife's vehicle listed above. There is no online information on how to do this to be found, but I did discover that in order to replace it, you must remove the catalytic converter from the drivers side which requires removal of the front prop shaft. It consists of a CV joint at each end with 6 Allen head bolts. I've removed the bolts but cannot get the the driveshaft flanges to separate from either the front differential or the transfer case. One person advised hammering on the ends but I cannot seem to find an optimal place to hit that produces results. Someone help!
Jan 11, 2020 at 12:44 PM
