Sorry for the late reply. Interestingly all the manuals are very short in the description for the starter replacement of this vehicle.
The two primary items that you will have to remove are the air intake system and the throttle body. It will be helpful to remove the battery as well. It will give you a little more room.
There are a couple of bolts at the bottom of the air tubing close to the firewall, kind of hidden, that will need to be removed to get the tubing out.
Then the throttle body will need to be removed.
Here is a helpful video that shows what it will look like after the removal. They also point out the bolts.
https://youtu.be/aNwtsSD6zos
If you still need to complete this task, I hope this helps.
Let me know if you have any questions.
Thank you.
Mar 19, 2022 at 7:56 PM
