The relay is in the passenger compartment fuse/relay box. I attached a picture of what you are looking for. In the picture, it is identified as the ST relay.
As far as the no crank, it could be a few issues. Simple things such as a corroded or loose battery terminal, neutral safety switch can cause this. Also, you mentioned the starter is good. Has it been checked? Have you checked to see if there is power to the smaller wire on the starter when the key is in the start position? If there is no power, a relay or fuse can be an issue. If there is power, the starter is bad.
Take a look through these links. It shows how to check for proper power to the starter, how to check a relay, how to check the battery terminals.
https://www.2carpros.com/articles/starter-not-working-repair
Let me know if any of this helps or if you have other questions.
Oct 8, 2018 at 7:15 PM
