I have an ongoing problem with my starter. About 5 months ago I tried starting it and it would not start. There was no sound or anything, but the lights would come on, I could push start it. The battery was checked; it is fine. The mechanic replaced my started then about 2 weeks later it died again, the mechanic then said the ignition was damaged, and it was replaced along with another new starter. It was fine until it started needing me to start it a few times before it would start until it eventually did not start anymore, again. I went back to the mechanic and this time they said the fuses were burned from the last time the ignition got damaged. They fixed it, but now it's a month later and the problem is starting again. I need to start it a few times before it actually starts, which means it will die again. Please help! I am considering changing mechanics, but I would also like some advice, so I'm not just putting all my trust in one mechanic. I got the car 6 months ago used, and it had, 64000 Kms on the clock and the old key so they problem may have been temporarily fixed when I got it, I am not sure.
May 15, 2025 at 4:47 AM
