I need the full service procedure for the starter replacement and any tips to do it easier if there is.
Dec 20, 2020 at 11:10 AM
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny.
Here is the information you requested. Once you remove the starter motor from your car you can take it to any local auto parts store and they will test it for free. Here is a tutorial showing how to remove and replace a starter motor:
I've attached picture steps below on starter motor replacement for your Infiniti. Hope this helps and thanks for using 2CarPros.
Dec 20, 2020 at 12:17 PM
SKOOTER24
MEMBER
Are the numbers the torque specs?
Dec 20, 2020 at 12:22 PM
SKOOTER24
MEMBER
I can't tell if there foot or inch pounds.
Dec 20, 2020 at 1:46 PM
DANNY L
CERTIFIED EXPERT
Hello again.
Sorry, I couldn't tell what those numbers were either. The correct torque specification for you starter motor bolts are 35 Ft. Lbs. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 21, 2020 at 4:03 PM
SKOOTER24
MEMBER
Thank you and I finally figured it out. I looked it up and saw what the tool signs mean.
Dec 21, 2020 at 4:19 PM
DANNY L
CERTIFIED EXPERT
You're welcome!
Let us know if you have any further questions on this issue. Thanks again for using 2CarPros and hope you will use our site again in the future. Happy Holidays.
Danny-
Dec 21, 2020 at 4:34 PM
SKOOTER24
MEMBER
Can I rebuild it ?
Dec 22, 2020 at 9:37 PM
DANNY L
CERTIFIED EXPERT
Hello again.
Not sure about that. You would have to search the internet about that. You can get a rebuilt starter for $100.00 and a new starter for $150.00 at auto parts stores. I've only rebuilt alternators. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 22, 2020 at 9:57 PM
SKOOTER24
MEMBER
Thank you and okay I'll try to find one then.
Dec 22, 2020 at 10:00 PM
DANNY L
CERTIFIED EXPERT
Hello again.
If you want to save a little more than a parts store you might want to try Ebay or Amazon if you have an account. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 22, 2020 at 10:09 PM
SKOOTER24
MEMBER
What would be a good way to get the manual for this vehicle?
Dec 23, 2020 at 11:43 AM
DANNY L
CERTIFIED EXPERT
Hello again.
The companies Haynes and Chilton make repair manuals for your car. I've attached a picture below of a Haynes manual from the AutoZone auto parts site. Hope this helps and thanks again for using 2CarPros.
Danny-
Image (Click to enlarge)
Dec 23, 2020 at 11:56 AM
SKOOTER24
MEMBER
I'll probably try it out then.
Dec 23, 2020 at 1:34 PM
DANNY L
CERTIFIED EXPERT
Hello again.
Sounds good. Thanks again for using 2CarPros and hope you will use our site again in the future. Happy Holidays.
