Engine will not crank
2006 MAZDA 6
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
CHELSIDIANE1988
My car will not turn over but it's got a new battery and the lights and everything will come on. Starter gone bad possibly?
Mar 20, 2021 at 5:39 PM
Could be the starter. However, let's start with checking the voltage at the starter when cranking the engine.
here is a guide that will help with this:
https://www.2carpros.com/articles/starter-not-working-repair
You should have 12 volts on both wires. The red/black wire will have it all the time. The red/yellow one will only have 12 volts when you are cranking the engine.
Let me know if you have questions and what you find. If you have 12 volts on both then the starter is the issue. If not then we need to dig into that. Thanks
Mar 21, 2021 at 6:23 PM
CHELSIDIANE1988
Thank you so much it was the starter after all. I replaced the starter and still couldn't crank the car but turns out that was just due to the terminals needing to be replaced.
Mar 22, 2021 at 4:31 PM
Great info. Thanks for coming back to update us. That is something that I forget to mention all the time so I am glad you found it and updated this so that all that visit this in the future will get that as well. Thanks for using 2CarPros.
Mar 23, 2021 at 5:14 PM
