Starter not disengaging sometimes
2007 DODGE
146,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
HAMBONE887
  • 24 POSTS
Hey everybody I am having an issue with my dodge nitro sometimes when I go to start it the starter will continue to try to start the car even after I have release pressure on the key and the key will be stuck in the start position until I pull it back to stop position. I have heard of some dodges having issues with the TIPM power control module.Any ideas of what this could be it doesnt do it all the time only sometimes but its still annoying.Thanks for any help.
Jan 14, 2016 at 9:02 AM
HMAC300
  • 48,601 POSTS
try a new starter relay and if it continues have it scanned for codes it may be the tpim is bad
Jan 14, 2016 at 9:29 AM
HAMBONE887
  • 24 POSTS
ok yeah I guess that is a cheap and easy fix ill give it a try thanks!
Jan 14, 2016 at 5:17 PM
CJ MEDEVAC
  • 11,004 POSTS
WITH THE KEY STAYING STUCK IN THE "START POSITION" THIS SOUNDS LIKE AN IGNITION SWITCH OR MECHANICAL ISSUE WITH THE LOCK CYLINDER MECHANISM
THE MEDIC
Jan 14, 2016 at 8:00 PM
