Vehicle will not start, starter will not crank the engine
2004 JEEP CHEROKEE
100,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JOHN CRANE4
Tried new relay and new starter. have power first time i changed relay it ran for a day. you can hear relay click. fuse is good. looked for the safety neutral switch couldn't fine it just the 2 speed sensor. tried to start it nothing. starting system is pretty cut and dry, but it has me stumped. only thing i haven't done to check neutral switch is put E brake on and put vehicle in reverse see if reverse lights come on to test neutral switch.
Jun 27, 2019 at 2:24 PM
Can you move the shift selector to neutral to see if it starts? We are losing power somewhere. here is a guide to help you test for power and the starter wiring diagrams so you can see how it works:
Jun 29, 2019 at 7:10 PM
JOHN CRANE4
Think it's the anti theft system starter system everything works.
Jun 29, 2019 at 7:13 PM
Is the security light flashing when you try and crank the engine over? If so lets use this guide to reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jun 30, 2019 at 10:01 AM
