Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine
Starter
Symptoms
Grinding
Starter makes loud grinding noise
1998 CHEVROLET BLAZER
200,000 MILES • 4.6L • 6 CYL • 2WD • AUTOMATIC
JEDCASTO
MEMBER
1 POST
FOLLOW
I tried putting shims in, but still makes noise.
Jan 25, 2020 at 10:43 AM
CERTIFIED EXPERT
Good afternoon,
Did you replace the starter? The end gear could be damaged.
Did you check the flywheel for any damage? That is a common issue. check the teeth for any grinding off of the teeth.
Jan 25, 2020 at 11:23 AM
