I cannot find the location of the actual starter..
Jul 27, 2019 at 10:38 PM
SCGRANTURISMO
CERTIFIED EXPERT
The information that you requested about your vehicle is in the diagrams down below. Please go through this information and let us know how things progress. If you need any instructions at all, like how to remove or install the starter motor on your vehicle, please, do not hesitate to ask. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Jul 28, 2019 at 12:47 AM
VIRGINIACLUCAS
MEMBER
1 POST
I need to know where to find the starter on a 2004 Honda CRV?
Jan 4, 2021 at 10:04 AM
(Merged)
CERTIFIED EXPERT
Starter Motor
14. Front of Engine (Intake Removed) Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
MRED1980
MEMBER
How do you get to the back bolt to replace the starter ? The last time I replaced a starter on vehicle was in the 1980's and it was easy?
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
May have to jack up engine slightly to gain access. Below are the proper replacement procedures.
This guide will walk you through the repair with diagrams below to show you on your car.
(Merged)
MRED1980
MEMBER
Eveybody keeps telling me to remove the two bolts, but what do I need to do to access the rear bolt? I just can't seem to reach it.
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
would raising the engine slightly help you reach it? if so, loosen the engine mount and slightly raise the engine up some with a floor jack
(Merged)
MRED1980
MEMBER
Honda's aren't like other motors. there is not a lot of space to move around. It's not simply remove the bolts, disconnect the power, then reverse the process but I did it!
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
