Where is the Starter located?
2015 NISSAN PATHFINDER
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHALIE10
I want to replace it and could use diagram as I am unable to locate.
Jun 21, 2023 at 9:59 AM
MATHGEN
  • 128 POSTS
The starter motor can be found on the passenger side of the vehicle where the engine and transmission meet. Here is a diagram that should help. Also, here is a link outlining the general procedure for replacing the starter. The main thing to remember is to disconnect the negative battery cable from the battery before starting the replacement.
Jun 21, 2023 at 6:56 PM
