Starter location needed
2014 FORD ESCAPE
63,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DLO BROWN
  • 5 POSTS
Starter location.
Jan 21, 2021 at 10:37 AM
Good afternoon,
I attached the procedure and some pictures for you.
The starter is at the bottom of the motor in the front of the car where the engine and transmission come together.
Starter Motor
Removal
1. Refer to: Battery Disconnect and Connect See: Battery > Removal and Replacement > Battery Disconnect (414-01 Battery, Mounting and Cables, General Procedures).
2. Refer to: Jacking and Lifting - Overview See: Vehicle Lifting > Procedures > Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
3. If equipped.
4.
5.
6.
7.
8.
9.
10. Refer to: Starter Motor Drive Gear and Flywheel Ring Gear Inspection See: Starter Drive/Bendix > Component Tests and General Diagnostics > Starter Motor Drive Gear and Flywheel Ring Gear Inspection (303-06C Starting System - 2.5L Duratec (125kW/170PS), General Procedures).
Installation
1. Torque : 35 lb.ft (48 Nm)
Jan 21, 2021 at 10:59 AM
