i have had my starter replaced twice still having issues. The vehicle in question is a c1500 truck. Originally the starter was making noise. I had it changed. And at the point it was still slightly louder than normal. But it was bearable. Then about 4 months later. It went out again. The next mechanic put on another one, then told me I needed to change the flywheel. He changed the flywheel which had no broken teeth or break cracks or bends anywhere. After putting the new flywheel and new starter in. It starter but again loud grinding noise start. 2 days after that. It wont start at all! There is 3 shims on the ground underneath my truck. And now the mechanic has a attitude. He says its ding that now because it is missing the starter mounting bracket. I mean you would think he noticed the missing bracket. Before he removed originally? Anyway to make matters worse the dealer is telling me that the vehicle does not even come with a rear starter bracket. Supposedly this part number 23502557 is the GM 1988-1999 starter bracket. But when I look up that part it says not compatible to my vehicle. I don't know what to do. Here is my VIN number: 2GCEC19H5P1160529. Help! Ray
Jun 25, 2020 at 9:21 AM
