Hi Oldlegger,
Starter is located at rear of engine below the intake manifold.
Here are removal procedures:
Starter removal and installation
Removal:
1 . Make sure you have the anti -theft code for the audio system and the navigation system (if
equipped), then write down the audio presets.
2 . Disconnect the negative cable from the battery first, then disconnect the positive cable.
3 . Remove exhaust pipe A.
4 . Remove the intake manifold bracket.
5 . Remove the harness clamps (A) and harness connector (B) from each clamp.
6 . Remove the two bolts securing the starter, then remove the starter from the engine.
7 . Disconnect the starter cable (A) from the B terminal. Disconnect the connector (B) from the
S terminal, then remove the starter.
Installation:
1 . Install the starter cable (A) and connector (B). Make sure the starter cable crimped side of the ring terminal faces away from the starter when you connect it.
2 . Install the starter, then loosely install the upper mounting bolt (A) and lower mounting bolt (B).
3 . Tighten the upper mounting bolt, then tighten the lower mounting bolt.
4 . Install the harness clamps (A) and harness connector (B) to each clamp.
5 . Install the intake manifold bracket.
6 . Install exhaust pipe A. Use new gaskets (B) and new self -locking nuts (C).
7 . Connect the positive cable to the battery first, then connect the negative cable.
8 . Start the engine to make sure the starter works properly.
9 . Enter the anti -theft code for the audio system and the navigation system (if equipped), then enter the audio presets.
10 . Set the clock (on vehicles without navigation).
Jan 22, 2021 at 1:25 PM
(Merged)
